Using gesture key for shortcut
NW5o4vTsxVyAY4AY
Post by NW5o4vTsxVyAY4AY » Feb 5th, ’19, 15:40
first off thank you for developing this software.
I'm having trouble making my gestures work when my gesture key, right mouse button, is also used for shortcuts.
More specifically, I'm using the right mouse button along with mouse wheel up and down to switch between tabs in Firefox.
I created these two shortcuts along with a third one so the native function continues to work.
The shortcuts are working perfectly fine and as intended, but when I enable them, my mouse gestures no longer work inside Firefox (the ones that are set exclusively for the Firefox windows).
I would like to know if this is a known conflict or if I'm just missing a crucial step somewhere.
Post by Marko » Feb 8th, ’19, 14:32
Sorry but currently this is not supported. You could change the gestures key to Ctrl+RButton or similar.
NW5o4vTsxVyAY4AY
Post by NW5o4vTsxVyAY4AY » Feb 9th, ’19, 19:48
Alright, no problem. Thanks a lot for the confirmation.
Best regards.
