Show start menu at cursor
Nmk
Post by Nmk » Jan 31st, ’19, 09:43
Hello!
I have two menus. One of them works like it should and opens permanently on cursor position. The liitle bit more complex menü randomly shows up in the upper left corner or on the position where my less complex menu has shown up last.
My settings
Show menu on: none
Menu delay: 500 ms
Top edge zone (L-R %): 10-90
I have three screens but I don't think this might be intersting for this problem. The working menu is Menu #1.
Is there any way to improve my settings?
Regards
Post by Marko » Jan 31st, ’19, 16:47
Both menus should work the same way. Set the two different shortcuts and set both "Show menu on" options to None in Preferences/Start Menu #1 and #2.
