using in whatsapp to avoid new message
Sway
Post by Sway » Dec 12th, ’18, 12:09
Hi, couldn't find how to do this, i want to use fastkeys in whatsapp desktop platform, if i can get this going then i'll be buying straight away as love the idea and it's awesome thanks.
If i have a paragraph being sent then each new line is a new message in whatsapp.
I won't explain further as I expect there is a quick answer to this if you could let me know please?
Sway
Post by Sway » Dec 12th, ’18, 16:08
let me add that in whatsapp desktop program, if you hold shift and press enter a new line is taken without sending the message, if there is a way of inserting this into the paragraph?
Post by Marko » Dec 12th, ’18, 19:40
Try this:
First line{Shift Down}{Enter}{Shift Up}Second line
or if you have modifier characters enabled in Preferences/Text Expander:
First line+{Enter}Second line
Sway
Post by Sway » Dec 13th, ’18, 04:41
awesome dude thank you very much! my life is now massively enhanced :D yay!
Kudos to you!
