FastKeys Won't Load
gsechler
Post by gsechler » Dec 7th, ’18, 19:43
Good Afternoon All,
A week or so ago, I noticed that my FastKeys program was having issues loading and it never seemed to be running anymore. I tried uninstalling and reinstalling, but I had no luck in fixing this. I was out of town for the past few days so today's the first time I've had to really give this a shot to fix it. Again, uninstalled and reinstalled this morning (to a different location that before). Upon running FastKeys, the program loads the small loading status bar and then the FastKey icon appears in my notification bar until I mouse over it. It then closes immediately.
I pulled the following information about the event from my Window's Event Viewer. Any suggestion on how to fix this would be greatly appreciated as I need my hotkeys back as soon as possible. Thanks!
Faulting application name: FastKeys.exe, version: 1.1.24.2, time stamp: 0x586eb98c
Faulting module name: FastKeys.exe, version: 1.1.24.2, time stamp: 0x586eb98c
Exception code: 0xc00000fd
Fault offset: 0x00022f33
Faulting process id: 0x4db0
Faulting application start time: 0x01d48e63f5c33fbb
Faulting application path: D:\Program Files (x86)\FastKeys\FastKeys.exe
Faulting module path: D:\Program Files (x86)\FastKeys\FastKeys.exe
Report Id: 7ffee82a-6b65-4ef3-ba5c-60ea935a81ee
Faulting package full name:
Faulting package-relative application ID:
Post by Marko » Dec 7th, ’18, 21:36
Could you check if FastKeys is blocked by anti virus or similar software?
gsechler
Post by gsechler » Dec 7th, ’18, 22:22
I'm running Norton and I've checked everything I can think of there. It all looks good and options related to FastKeys are all set to "Allow."
Post by Marko » Dec 8th, ’18, 10:46
Can you send your settings.fdb and settings.ini files from FastKeys/Data folder to our support mail?
wetware05
Post by wetware05 » Dec 11th, ’18, 16:06
Because of my experience, we have to delete the directory "c:\Users\<user_name>\Documents\FastKeys Backup\", a macro was recorded that was not closed. Make a backup before.
