How to send parentheses
dlhtox
Post by dlhtox » Nov 12th, ’18, 14:08
For some reason I cannot find this in the documentation.
When I have something such as "Program Files (x86)" it comes out as "Program Files (x*^)".
I see that the ( is causing it to shift the keys for 8 and 6, but I don't want this. I need to send the parentheses itself.
It does this even though I have "Send Raw Text" selected.
Is there documentation on these special characters and how to get them to send rather than perform a function?
Many thanks.
Post by Tom » Nov 12th, ’18, 14:48
I tried but cannot get this on my computer. Which language are you using?
You can also send your settings.fdb and settings.ini files to our support mail and I can check further.
