I need HELP
pozarlodu
Post by pozarlodu » Aug 30th, ’18, 23:48
i have big problem. how to remap key for holding purposes? so i can holding for example letter "m" like "shift" and when i droped, everthing back to normal. When i use command "Hold the Shift key down until {Shift Up}" on random key, i press that key and get constant "shift" pressed, then i must find real shift to turn it back. i have hope that you are understanding me right. my English is bad. i just wonna hold remapped key till i let go. for example turn letter "m" to "shift" and thet letter "m" will be working like shift. Please HELP, i need this so bad. Thank you for help...
Post by Tom » Sep 2nd, ’18, 16:41
This script changes "m" key to act like a Shift. Is this what you need?
Send {Shift down}
KeyWait, m  ;wait for m to be released
Send {Shift up}
Type: Command
pozarlodu
Post by pozarlodu » Sep 2nd, ’18, 18:40
YES YES YES it's wok
THANK YOU VERY VERY MUCH :D :D :D :D
