vrod5454
Post
by vrod5454 » Aug 30th, ’18, 21:22
I am able to make the date command script below work in a send via %INSERT_.mydate%.
Days:=8
BDays := 0
While (BDays < Days)
Today += 1, D
FormatTime, WDay, %Today%, WDay
If (Wday <> 1) && (WDay <> 7) ; not Sunday and not Saturday
BDays++
FormatTime, Date, %Today%, dd/MM/yyyy
Send, %Days% business days from now is %Date%.
Original code from https://autohotkey.com/boards/viewtopic.php?t=1818
To make the above command script more flexible... would it be possible to send the command the argument "days" - like a function{} ? For example:
would be plus 1 day- etc.
I understand that the date command script would need to be revised to accept the parameter.
Thanks,
Victor
Post
by Tom » Sep 2nd, ’18, 16:31
You can use INPUT variables in your code so:
Substitute:
%INPUT_NoOfDays% business days from today is %CODE_DaysCalculation%.
where CODE_DaysCalculation is
Days:=INPUT_NoOfDays
BDays := 0
Today += 1, D
BDays++
Send, %Date%
