When I want to do the %clipboard%-variable over several lines, for example:
1
2
3
it always turns out with a line spacing, having an outcome like:
1
2
3
Is there a way to get rid of that line spacing?
The problem exists in every program I use
Line spacing in %clipboard%
%Clipboard% variable contains the current contents of the Windows clipboard. Each line of text on Clipboard typically ends with carriage return and linefeed (CR+LF) and FastKeys types it letter by letter.
For general purpose it is better to use Paste instead.
^v
