How to autocorrect sentences?
orlando2bjr
Post by orlando2bjr » Oct 12th, ’17, 20:55
How can I achieve this with Fastkeys:
:*?:à postos:: a postos
It works fine in AutoHotkey.
Any workarounds?
orlando2bjr
Post by Tom » Oct 13th, ’17, 07:38
It works - you should enable "Trigger immediately" option.
orlando2bjr
Post by orlando2bjr » Oct 16th, ’17, 11:35
I couldn't get it to work. Can you help?
Settings
Gif
orlando2bjr
Post by Tom » Oct 16th, ’17, 13:37
What are your language/keyboard settings?
orlando2bjr
Post by orlando2bjr » Oct 17th, ’17, 10:37
Language - Portuguese (Brazilian)
Layout - ABNT2
As I said, weirdly this works fine with an AHK script. I read the documentation and checked the same options.
In this layout ` backtick is positioned two keys to the right of O, and needs SHIFT.
orlando2bjr
Post by Tom » Oct 18th, ’17, 10:16
Strange. I installed Portuguese (Brazilian) ABNT2 and exact same definition works as expected on my side. Could you verify again? Do you have any other active conflicting item?
If you still have trouble, you can send us your settings.fdb and settings.ini files to our support mail and we will take a look.
orlando2bjr
Post by orlando2bjr » Oct 18th, ’17, 16:42
Just tried with everything disabled but that, still nothing. Will send data now.
orlando2bjr
orlando2bjr
Post by orlando2bjr » Oct 19th, ’17, 19:40
Just now I was testing another autohotkey script (not in FastKeys, but it was running). And suddenly, Fastkey it is working perfectly again :O
What happened?
orlando2bjr
orlando2bjr
Post by orlando2bjr » Oct 19th, ’17, 20:22
Broken again. Maybe something to do with the parallel Autohotkey installation. I've uninstalled both and reinstalled FK, still doesn't work.
orlando2bjr
Post by Tom » Oct 19th, ’17, 22:05
I tried it with the settings file you sent. Everything works as expected on our end. You must be running some conflicting applications/commands!? Have you disabled all running AutoHotkey scripts (check Task Manager)?
