I'd appreciate help.
As showed in the snapshot below, there are several icons for tools in the app interface. There is no default shortcut and the only way to access the tools is by clicking on its respective icon.
Is it possible to create a command in which a custom shortcut will trigger the tools based on their icon/image?
Is there a command to trigger apps tools based on their icon/image?
In my Snagit version (13), the tools can be selected with a shortcut, for example Ctrl-5 for Fill.
In general, if a shortcut or Control Class is not available for particular control, you could use a click command to click a mouse button at the specified window coordinates. Get coordinates of the icon using Window Information tool. If needed, also set coordinate mode (screen or window).
https://autohotkey.com/docs/commands/Click.htm
CoordMode, Mouse, Window
Click 44, 55 ;get coordinates using Window Information tool
