Start Menu Recent Fles list purpose?
=Jagz=
Post by =Jagz= » Sep 16th, ’16, 03:01
What is the purpose of the Start Menu option to list recent files if you can't open the file from the list?
Post by Marko » Sep 16th, ’16, 18:38
Tested again and it works for me. You cannot open any item from the list? Files and folders? Which Windows version you use?
=Jagz=
Post by =Jagz= » Jan 5th, ’17, 21:02
Sorry for the delay, it was working for a while and now it's not working again.
I'm using 3.15. I click on the item and the menu goes away but the document or folder does not open.
Could it be a Windows setting or something?
UPDATE:
My Recent folders are opening, but not documents.
Here's a screenshot of my settings:
Post by Tom » Jan 6th, ’17, 11:52
Recent items rely on the links to items available in the Windows recent items folder. Could it be that your missing file was deleted or moved?
