Question about using "!" in scripts
Whenever I use a script and put a ! in, it writes it out at {!}. Is there something I'm missing in the settings? Tried to search the forums, but sadly no terms I tried were turning results and I can't search for just {!}.
Could you please give a script example? While sending text ! character is indeed sent as {!} to produce a proper result. Otherwise ! is a shortcut for Shift key.
