I wanted to create this shortcut Ctrl + Delete = Home but it does not work. The combination of ctrl + delete seems to be broken.
Shortcut - Ctrl + NumpadDel
Type - send
Command - Send {Home}
Any idea how to solve it? Thank you
Two things:
- there are variations of Numpad key names which depend on NumLock status. Press NumLock key or change the shortcut to Ctrl + NumpadDot. The best is to select a Shortcut input field and just press the right key combination.
- word "Send" in your command is not needed, in Send type you just need "{Home}" instead of "Send {Home}".
