After automatic update to v3.01 all data+spripts disappeared
cadudesun
Post by cadudesun » Jun 8th, ’15, 19:56
After Fastkeys automatic update all the data is disappeared.
The left menus are empty (text expander, start menu, etc).
For instance, since start menu is empty, all my AHK commands also disappeared.
I double check the folders in preferences and also tried to load the .ini + .fdb from backup, but the problem remains.
I would really appreciate any tip to solve this problem.
Many thanks,
Cadu
Post by Marko » Jun 8th, ’15, 20:14
FastKeys doesn't overwrite a Settings.fbd file or any other setting file (except for Examples.fdb) during the update so this should not happen. I wonder what went wrong...
Backups are located in Documents\FastKeys\FastKeys Backup folder (My Documents in Win7). Please find the latest file with your settings, copy it to the Data folder and open it with FastKeys.
You can send me a content of your FastKeys Backup folder to [email protected] and I will try to help.
