Hi, great and extremely useful application.
I have noticed the portable version is also available. I work on a company computer and software setup is restricted by IT policy. Can I still use the portable? What is the main difference to regular version? Thanks.
John
FastKeys portable
The portable version is essentially an unzip of files to selected folder and doesn't require administrator setup privileges. Functionality is exactly the same as with regular version. So yes, you can use it on restricted systems.
Thanks, just registered. I'm using it on my work computer for some time without any issues. Works well and greatly improves my daily productivity.
Very little money very well spent. Thanks
Thanks John.
