HTML support
stevenjc
Post by stevenjc » May 14th, ’14, 07:47
Hi
I am unable to see how I am meant to be able to insert HTML code into an auto-text entry. Am i missing something or is this not supported?
Post by Marko » May 14th, ’14, 11:21
could you be more specific? What would you like to do and what's the problem?
In Text Expander, you can open the Phrase file "Html Coding Abbreviations" for many examples.
Mark
Post by Mark » Jan 13th, ’15, 12:31
I guess I have the same issue, what I am doing wrong? How I am supposed to insert HTML snippets?
Thanks in advance for any help!
Post by Marko » Jan 13th, ’15, 12:37
Not all editors support HTML. Try in Word or any other application which supports rich text.
Mark
Post by Mark » Jan 13th, ’15, 13:40
thanks :) just want to add my solution: I had to wrap < > into {}
Example: {<}foo{>}hello world{<}/foo{>}
PS since I couldnt find a way to reset the HTML flag on an existing entry in FastKeys (the dark grey "HTML" on the lower right beside the text field), I required to do a new one, else it seems to me it is always pasted as rich text
Post by Marko » Jan 13th, ’15, 13:47
You can turn off the HTML by right-clicking on command field and un-selecting Send HTML option.
