This is a daily error, I think is trouble with another app named ''ClipboardFusion Pro 3.1.1, do u have any suggest to avoid this message error that appear each time I copy a text?????.
It says: '' Can't open clipboard for reading Line #10555: } 10556; if OptMem =1.... etc.'', God bless u. (your forum does not let me post the error image)
Clipboard message error
Hi and welcome to the forum.
Some applications are known to block the access to clipboard for their purpose. If this is the case you can go to Preferences/Clipboard Manager and either delete a Clipboard shortcut (press delete) or set History size to 0. This will disable FastKeys Clipboard Manager so there should be no conflict.
Please let me know if this solves your issue.
