Tabs finally!!!
Thanks for introducing a proper tab structure to the program. I mainly use text expander with many abbreviations for different purposes and I really struggled with non ability to properly organize them. Now we are talking, this puts the software into different league!! Thank you.
Now when we have tabs you could allow definition of few more Start Menus...
Would this be possible?
That's a good idea. Maybe different start menus for differente edges of the screen.Gmasd2m wrote:
Exactly, or with different shortcut keys... Different menus for different purposes...
Thank you, this was already considered and may be implemented in one of the future versions. This would bring many additional preference settings so it must be carefully structured (the number of menus, general settings, specific menu settings etc.).
What do you think? Any further ideas are appreciated.
I thought something like this:
Replace 1 with 2 or 3, or even allow custom names for each start menu.
Same thing for the Setting windows.
Now we have tabs, so why not a tab for each start menu?
thanks, I can add preferences to add shortcuts and edge trigger definitions for few more menus. If additional menu(s) will be defined by the user, the information from available tabs would be used to build menus. If not, the information from all tabs will be used for a first menu (as it is).
What do you think? I guess three extra menus would be enough...
