Can you remove or change the behavior of the menu?
I like the idea of the menu that shows up when you put the cursor to the top of the screen, but it doesn't work in practice for me. I'm in Chrome all of the time and am constantly bumping up against the top of the screen with my cursor on different tabs.
Yes, there are actually four ways of calling the Start Menu:
- touching the top screen edge,
- touching the right screen edge (alternatively),
- pressing pre-defined keyboard shortcut,
- selecting Open Menu from Tray icon.
All these can be set by user in Program Preferences.
By the way, I'm using Chrome tabs with no problem. I guess it is matter of practice...
