Ive found the command for the computer to hibernate but I prefer sleep because you can wkae it up with a mouse movement.
What is the command I should put into the coding box to make my computer go to sleep. Thank you
what is command to get computer to go to sleep
I believe this is only possible by changing Windows settings - Windows prefer hibernation by default.
