First, thanks for this wonderful program. It really is a pleasure to use and does so many things I've long searched for. I wish I had it when I used a Windows Tablet because it would have saved me tons of frustration.
So...
I'm a playwright and like to create shortcuts for my character names by pressing just the first letter of the character's name.
So I have a character named Tom with the string for activating the shortcut the letter t.
It works fine until I type a word like can't and then it thinks the t at the end is a separate word and changes it to can'tom.
Is there any workaround for this, so it doesn't expand words with apostrophes?
I know I shouldn't be creating shortcuts with single letters, but it's the way I've come to work.
Thanks.
Dealing with apostrophes and Text Expander
Apostrophe is one of the ending characters as defined in Preferences/Text Expander. Remove it from the list and try if it works for you.
