Clipboard Manager - button "copy"
marcelolima
Post by marcelolima » Jan 26th, ’23, 01:28
Hello, Team.
The clipboard manager's "copy" button should work, right? (image below)
In my case it is not working. Should I change any settings?
Thanks.
Best Regards,
Marcelo.
:arrow: :arrow: https://imgur.com/a/YqtAdET
Post by Tom » Jan 28th, ’23, 22:03
What kind of the content are you copying? For images it is sometimes better to simply press Ctrl+C.
marcelolima
Post by marcelolima » Jan 28th, ’23, 22:48
I'm only trying to copy texts, not images.
I am using Crtl+C because copy button has don`t works. But ok. This is not a big problem.
Thanks.
Post by Marko » Jan 29th, ’23, 15:24
It works for me, maybe check the settings.
