Hello, I wanted to know if it is possible to sync this software between 2 or more PCs, either automatically or manually.
By sync, I mean everything, from text expand to each & every small change in preferences, so that the software behaves exactly the same way between 2 PCs, including how the key combinations behave, the default prefix & suffix, enabled and disabled modules and such.
Sync everything between 2 or more PCs
Sure, simply use the settings file from a shared location (network, OneDrive, Google Drive, DropBox etc.). Use “File/Save as” to save the file to a shared folder and “File/Open” on another computer.
There are more advanced sharing features for larger teams available in Enterprise and Professional Editions.
How to import settings .ini file?
When I tried copying the whole folder from one PC's "Documents" folder to another PC's "Documents" folder, my shortcuts and text expanders did copy but the settings/preferences didn't load.
