On the YouTube video showing how to query a spreadsheet, I asked if it was possible to do the opposite, and use prompts to enter data into an ever-growing spreadsheet. The reply was to contact support, so I thought I'd ask here in case others are curious.
I track various jobs I do in a spreadsheet with usual columns for Client, Address, etc, and think it would be nice to have a prompt to enter the data in, and it go and enter it into the spreadsheet automatically if possible.
May be another post altogether, but could utilize the same thing for entering appt's on Google Calendar (client, address).
How about inputting into a spreadsheet?
You could use the COM object to access Excel. For example this code (Type: Command) will ask for the input value and write it to cell E5 in the Excel file. Of course you can change the file path and the cell range as you wish.
Here is one of the tutorials to learn about Excel COM if you wish to develop it further.
https://www.autohotkey.com/board/topic/ ... for-excel/
InputBox, CellValue, Input, Enter the value, , 200, 120
fn := "D:\MyFolder\Sales.xlsx"
tooltip Writing to Excel
oExcel := ComObjCreate("Excel.Application")
oWorkbook := oExcel.Workbooks.Open(fn)
oWorkbook.Sheets(1).Range("E5").Value := CellValue
oWorkbook.Save()
oExcel.Quit()
oExcel:=""
tooltip
