hi,
when FastKeys is opened, any shortcut `alt+key` sends a ghost `ctrl`. This interferes with other programs I use (fluentsearch, tvpaint, ...)
from Autohotkey doc, this is related to #MenuMaskKey (https://www.autohotkey.com/docs/command ... askKey.htm and lso https://www.autohotkey.com/board/topic/ ... r-hotkeys/)
is there an option or manual way to change #MenuMaskKey for FastKeys ?
I'd like to set it to `#MenuMaskKey vkE8` in order to stop sending `control` after a shortcut
alt+shortcut sends a ghost `control`(#MenuMaskKey)
Try adding the #MenuMaskKey command into the Tools/Startup code and let me know if this works for you.
