Form macros add dot and extra comma
BrittMalka
Post by BrittMalka » Nov 23rd, ’22, 08:49
I have FastKeys v. 5.09 professional licence.
I've made a Text Expander "send" thing that should create a form, and it has worked (I'm pretty sure), but now it adds two weird things.
Here's the output:
<form method="post" action="LINK">
    <input type="hidden" name="idGroup" value="1">
    <input type="text" name="FNAME" placeholder="First name" value="">
	<input type="text" name="LNAME" placeholder="Last name" value="">
	<input type="email" name="email" placeholder="Email" value="">
    <input type="hidden" name="idList[]" value="1•,4">
    <input type="hidden" name="tags" value=",1,2,26">
    <input type="hidden" name="prefers" value="0">
    <input type="submit" value="Subscribe">
</form>
If I only pick one value for list, it does it correctly.
Whether I pick one or more values for list, it starts with a comma.
I cannot figure out why that happens.
Here is my send command:
    <input type="hidden" name="idList[]" value="%SELECT_nvmlist%">
    <input type="hidden" name="tags" value="%SELECT_nvmtags%">
</form>
Here's a screenshot of my first select:
https://a.cl.ly/NQu4Emb9
And my second:
https://a.cl.ly/OAu2w1Rz
Can you see what's going on and why it adds two weird characters?
Update (because I kept testing): I found that if I removed one of the select macros, then it worked. But I need both to create the form. Is there a way to do that?
Thanks,
Britt
Post by Marko » Nov 23rd, ’22, 22:07
Hi BrittMalka, this is strange and I couldn't reproduce it on our systems. Could you please contact our support mail so we can test this further? Thanks.
BrittMalka
Post by BrittMalka » Nov 24th, ’22, 06:38
Thank you. Done.
