Hello, when the "Focus to-do" application is open, and I try to open the start menu, the "Focus to-do" window is restored instead of opening the start menu, the problem appears even with the shortcut configured.
I have the start menu configured as a toolbar.
To open the start menu, I am forced to close the "Focus to-do" application, then open the start menu and finally reopen "Focus to-do".
I use Windows 11 and this is the application with which there is a conflict:
https://www.focustodo.cn/
The problem is even with the "Focus to-do" chrome store add-in
Thanks for any help.
Open the start menu
I installed and tried the app and it works for me, FastKeys toolbar opens normally when the app is running.
Maybe you need to change the toolbar shortcut to something else.
