Output in Capital Letters
ped
Post by ped » Sep 12th, ’22, 10:16
How is it possible -- if at all possible -- to output the user input in capital letters, for example?
User Input: bmw ---> Output: BMW
Here in pseudo-code where UPCASE() is a function:
UPCASE(%INPUT_ACRONYM%)
Post by Marko » Sep 12th, ’22, 10:35
Check "Output format" macro options.
ped
Post by ped » Sep 12th, ’22, 11:10
I had some difficulty understanding exactly what you meant, but somehow I figured it out.
Here for other users who may have the same problem:
Thank you very much for your quick help.
