Clipboard - Paste Multiple Items
Hopps81
Post by Hopps81 » Jul 21st, ’22, 14:42
Is it possible to paste multiple keyboard items into a phrase? I just switched over from PhraseExpress and this was a function they had, but I can not find it on FastKeys? I often copy 2 text items so that they can be pasted into an email template using a phrase command. So in the below the last thing I copied would be pasted into {insertclipboard -item 1 -variablename Insert text from clipboard} and the 2nd to last thing I copied would be pasted into {insertclipboard -item 2 -variablename Insert text from clipboard}. Possible with FastKeys?
{insertclipboard -item 2 -variablename Insert text from clipboard} - {insertclipboard -item 1 -variablename Insert text from clipboard}
Post by Marko » Jul 21st, ’22, 21:43
This feature is currently not available. However, it is on our development list an will be ready in one of the next updates.
