Can not open stay-on-top Clipboard Manager.
RadioGregg
Post by RadioGregg » Jul 10th, ’22, 08:31
When I right click the icon in the task manager and choose Clipboard Manager, nothing happens...any suggestions on how I get this Clipboard Manager back? Many thanks! Gregg
Post by Marko » Jul 10th, ’22, 20:44
Are you using multiple monitors? Try to extend display to all monitors and then reposition Clipboard Manager.
Are you using the latest FastKeys version?
RadioGregg
Post by RadioGregg » Jul 13th, ’22, 02:19
Thanks for your help!
I am using the latest version.
I am using multiple monitors and I am extending the display to all monitors.
So I just unplugged the monitors, shut down FastKeys and restarted it...and there it it!
It also works now with the monitors plugged in...thank you!
