Ennovy
Post
by Ennovy » Jun 8th, ’22, 10:27
I want to have a menu item that exports a registry key:
Can you help me please with the correct syntax, because what I have so far doesn't work
The file delete is executed, but not the second line of the script
FileDelete p:\werkmap\TheBatBackupRegistrykey.reg
run, "%windir%\System32\REG.EXE EXPORT" HKEY_CURRENT_USER\Software\RIT p:\werkmap\TheBatBackupRegistrykey.reg
Thanks,
Peter
Ennovy
Post
by Ennovy » Jun 8th, ’22, 11:06
I found the correct syntax for my script:
run, reg export HKEY_CURRENT_USER\Software\RIT p:\werkmap\TheBatBackupRegistrykey.reg /y
Have a nice day!
Peter
