Let's say I want to start Thunderbird, which is password protected.
When I give the password followed by the <ENTER> key I get a message that the password is not correct.
When I give the password followed bij clicking OK with the mouse the password is accepted.
How can I prevent this? Because it's a FastKeys issue, when I close FK there's no problem.
Thanks in advance for your support
Peter
Open password protected software
You probably have a password or a part of a password defined as one of your shortcuts or auto complete words.
What I meant is you should check FastKeys auto complete wordlists etc if you have such a word defined. Try disabling wordlists first to see if this is an issue.
