How to open D drive with totalcmd.exe in Shortcuts
You should check the command line parameters for Total Commander:
https://www.ghisler.ch/wiki/index.php/C ... CDirectory
Don't know how to write itTom wrote: ↑Feb 11th, ’22, 20:43 You should check the command line parameters for Total Commander:
not a programmer
do you have an example
Does FastKeys have its own environment variables?system wrote: ↑Feb 12th, ’22, 01:00Don't know how to write itTom wrote: ↑Feb 11th, ’22, 20:43 You should check the command line parameters for Total Commander:
not a programmer
