Pop up scroll with multiple monitors
When I have a large input popup, the scroll option does not appear while using dual monitors. In order to scroll through and complete the input popup, I have to disconnect my extra monitors and use only my laptop. Is there a way to change the setting so that the scroll option appears on the input pop up while using multiple monitors?
I tested it on our monitor configurations and it works as expected. Could you please contact our mail support for a specific help?
