5.04 Update failing
mrmcwn
Post by mrmcwn » Jun 28th, ’21, 12:08
Keep getting an error message: Can't delete file, code 5 or similar. Do we need to uninstall and clean install rather than use the updater?
Post by Marko » Jun 28th, ’21, 12:13
In such case, make sure you first exit FastKeys (don’t uninstall) and then download and install a new version manually. You will be asked to import the settings.
