menu icon file specs
acquafastkeys
Post by acquafastkeys » Feb 7th, ’21, 11:44
What kind of file are expected, beside exe, to work as icon in the start menu ?
I've got a lot of links to website with "C:\" icon, how can I use telegram/reddit icon ?
EDIT: ok turns out that renaming a png to .icon extension works
EDIT 2: software "forgets" about these file, when I added them it worked but now they don't display anymore
thanks
Post by Tom » Feb 7th, ’21, 18:48
Most web page links should display the icon automatically. For others you can specify any file containing the icon (exe, ico etc.).
acquafastkeys
Post by acquafastkeys » Feb 7th, ’21, 19:11
reddit and telegram don't work, I tweaked a fake exe to make it work
acquafastkeys
Post by acquafastkeys » Feb 9th, ’21, 02:09
Tom wrote: Feb 7th, ’21, 18:48 Most web page links should display the icon automatically. For others you can specify any file containing the icon (exe, ico etc.).
looks like sometimes fk won't import .ico at all
https://i.imgur.com/bXxjD5w.mp4
but if you paste the path works
Post by Marko » Feb 9th, ’21, 21:18
Thanks, this will be corrected asap.
acquafastkeys
Post by acquafastkeys » Feb 17th, ’21, 02:54
Marko wrote: Feb 9th, ’21, 21:18 Thanks, this will be corrected asap.
looks like the icon bug was fixed, am I right ?
btw are goin to get a icon choice for the submenu name ?
Example:
the "web" tab doesn't display any icon
not that I really care, it was just to nitpick
Post by Marko » Feb 17th, ’21, 21:13
Parent menu icons are not available. It is on our wish list.
