Remove Formatting During Copy and Paste
DVT
Post by DVT » Dec 23rd, ’20, 21:03
Is there a shortcut to replace Ctrl + V with a paste feature that strips all formatting in FastKey? I need it to remove all text formatting from the clipboard and pastes the resulting pure text to the active window with the existing Ctrl + V. Thanks!
Post by Tom » Dec 26th, ’20, 11:24
There is an example shortcut available - Paste without formatting. Is this what you are looking for?
DVT
Post by DVT » Dec 28th, ’20, 22:41
Sort of. I used that shortcut and bind it to Alt + V. Is there a way to replace the current Ctrl + V to paste without formatting?
Post by Tom » Dec 30th, ’20, 09:41
Just change the shortcut to Ctrl + V. This should override the system shortcut.
