Multiple Classes
I teach multiple classes and need to use a different set of fastkeys for each class and unit. Is there a way I can do this in fastkeys? I've previously used type4me and could do it with that program.
Of course. You can create multiple settings files - File/Save As... and load them using File/Open.
I know this is a crazy question, but how do you do that?
Like in any other application. For example, you can create a new, empty settings file by selecting File/New menu and then add the items. Or you could save the existing file with a different name by using File/Save As menu.
Then you can load a settings file by selecting File/Open menu.
