How to wrap html tags around selected text?
abscaps
Post by abscaps » Sep 9th, ’20, 00:02
I currently use Sublime Text 3 as my text editor and the app has a great keyboard shortcut that can wrap any selected text with default <p></p> tags. Immediately typing any other tag like h1 will auto fill the beginning and closing tags. This is more useful in a lot of cases than using the html phrase file.
I haven't been able to see how to do this in Fastkeys. Can you point me in the right direction? Thank you.
Post by Tom » Sep 10th, ’20, 17:53
This example will wrap the selected text with the tag. Create a shortcut, Type: Command.
Clipboard:=""
Send, ^c
ClipWait
InputBox, MyTag,, Tag:,, 150, 120,,,,, p
if ErrorLevel or not MyTag
SendInput, <%MyTag%>%Clipboard%</%MyTag%>
abscaps
Post by abscaps » Sep 10th, ’20, 21:00
Wow! Thanks very much! I never would have figured that out. Cheers. :)
Post by Marko » Sep 28th, ’20, 08:30
Even better:
Type: Send
<%SELECT_Tag%>%Clipboard%</%SELECT_Tag%>
where SELECT_Tag is a Selection form macro with a list of tag selections.
