Adding a symbol (trademark)
skrug
Post by skrug » Jul 3rd, ’20, 22:47
First, I love this software. I've used ton of shortcut, macro, and text expander programs over the years, and this is THE best.
I seem to be stumped trying to do something that seems simple, though: When I type tm[spacebar], I want it to insert a TM symbol.
I've tried a bunch of things, read the online help, and searched the forum, but I'm still stumped. Any suggestions?
Thanks
Post by Tom » Jul 4th, ’20, 09:21
There is one in the Symbols Phrase file, the abbreviation is "ttm".
You can also make your own:
String: ttm
Command: ™
Hold left Alt key and type 0153 on numeric pad to enter the symbol.
You may want to enable "Trigger inside word" option.
