Strange SendRaw behavior
Oblomov
Post by Oblomov » Jun 13th, ’20, 13:30
As determined through an earlier thread, the correct usage of SendRaw in certain situations:
viewtopic.php?f=4&t=863
I have been using this command for Notepad++:
SendRaw, % "[\r\n]+"
Which has been working quite well, for a fairly long time. However today, I noticed that the command has suddenly taken on some very strange inconsistencies/inconsistency.
At first, the only input it was giving me was:
rn+
That, plus it executed a smaller command, along with it, which was very odd...
I then tried to:
• Restart FK
• Enable/disable FK
• CtrlAltDel
• Termination of an AHK script
However, only a PC restart helped, partially. As now, I get:
\r\n]+ and not the full [\r\n]+ that I always got before...
I 've now added an extra [, at the beginning, i.e.:
SendRaw, % "[[\r\n]+"
Which is fine, I mean as long as it works, it's whatever. But yeah, still really curious how something like this could have happened in the first place 🤔
Kind regards,
Post by Tom » Jun 13th, ’20, 14:01
If you use Type: Command, the output is always [\r\n]+.
If this is not the case, there must be a conflict with some other commands/settings.
Oblomov
Post by Oblomov » Jun 13th, ’20, 19:29
Tom wrote: Jun 13th, ’20, 14:01 If you use Type: Command, the output is always [\r\n]+.
It's type Command, but yeah, my only guess is that something is somehow corrupted, and that there is seemingly no way of resetting it... probably gonna try to copy over my stuff to a new portable installation, except settings, just to try anyway
