Popup and Selection form menu size issue
prasad383
Post by prasad383 » Apr 30th, ’20, 04:42
I wanted to change the font and size of text that appears on the popup and selection form menus. But after changing those settings in preferences, the sizes of these popups are not keeping with the text. How to reolve this issue ? I reloaded the fastkeys but it doesn't help.
Post by Tom » Apr 30th, ’20, 11:08
What do you mean? Can you repost the image?
prasad383
Post by prasad383 » Apr 30th, ’20, 11:26
Please see this screenshot. Window size is smaller and text is not shown completely.
https://drive.google.com/open?id=1oEbK6 ... _sX4HrJdiY
Post by Tom » Apr 30th, ’20, 11:44
The popup width is not fully resized. Thanks, we will improve this.
mparis5551
Post by mparis5551 » May 12th, ’20, 13:44
I use 2 monitors and sometimes the popup list shows on the other monitor. Any way to correct this?
Post by Marko » May 14th, ’20, 18:07
We'll check it out. ;)
