Just wanted to point out that sometimes, it seems as though while trying to define a shortcut, the program doesn't always disable shortcut execution. I.e. when you fill out the shortcut input, you may accidentally execute existing commands. This doesn't seem to happen often, but from time to time. Usually not that big of a deal at all really
Using this opportunity, I would also like to make a suggestion in regards to 'Checking for errors' process, it takes a very long time for me to finish, and I'm thinking, it would be really nice if one could cancel the 'Checking for errors' process, and just go from there. Removing the recently added or altered command, as I personally, always hit 'Apply', after any changes made to a command or the like. Would definitely help in regards to time-saving
Best wishes,
Occasional, small problem with addition of a shortcut and suggestion, in regards to error-checking
Thanks, we will take a look.
