benzol
Post
by benzol » Mar 25th, ’20, 14:50
Hello, I'm really new to FastKeys but quite like it so far and just ordered a personal edition.
I would like to create a command for opening a website and fill in username and password and hit login. I used the following script but it only opened the website without doing the following steps. I wonder if anyone could help me out here? Thank you!
Run, https://www.editorialmanager.com/advenergymat/default.aspx
WinWait, , Username,
sleep, 1000
Send, {Tab 3}usename{Tab}password{Tab 4}{Enter}
(the last {Tab 4} is to specify logging in through "Editor login")
Post
by Marko » Mar 26th, ’20, 21:45
WinWait is not useful as the page still needs to load - try experimenting with the Sleep length.
This works for me:
sleep, 4000
Send, {Tab 2}usename{Tab}password{Tab 4}{Enter}
benzol
Post
by benzol » Mar 27th, ’20, 04:37
Thank you Marko, this worked!
Marko wrote: ↑Mar 26th, ’20, 21:45
This works for me:
sleep, 4000
