I'm trying to set context window, as described in 6 of:
https://www.fastkeysautomation.com/docu ... ander.html
However, for some reason, I can't get it to receive priority over a text expansion, that has an empty 'Window' field.
And so, I have two commands with the same string, \d1. One of them Having 'Temp', inside of the 'Window' field, the other \d1, having nothing.
'Temp' is the name of a Notepad instance, in which I'm trying to execute the text expansion
Things I’ve tried:
• Changing the input inside of the 'Window' field with '*Temp - Notepad' and 'Temp - Notepad'
• Restarting FK
Context window seemingly, not quite working
The priority is dependent on the sequence of the items on the list.
Window setting defines the target window(s) in which the item is active.
Gotcha, re-adding the text expansion with an empty field, resulted in the distinctly desired behavior, in regards to priority
