How to create start menu items to trigger Fastkeys' "Quick Find" and "Quick Add" functionalities through the UI?
cadudesun
Post by cadudesun » Mar 3rd, ’20, 10:52
I'd appreciate your help.
Although in "Tools>Preferences" you can set shortcuts to "Quick find" and "Quick-add", I would like to add those Fastkeys' functionalities to its start menu, in order they become actionable from the UI as well.
Is it possible? How to?
Carlos
Post by Marko » Mar 5th, ’20, 19:38
Could you try the solution from this post?
viewtopic.php?f=4&t=868&p=3375&hilit=Sendlevel#p3375
