Is it possible to save a fkp phrase file?
It doesn't seem possible from the file menu (which appears to save only as .fdb).
I want to do this so that I can edit the fkp file as a simple text file in something like Notepad. Then it's easy to re-import it as an fkp or ahk file.
John
Can you save as fkp phrase file?
You cannot export regular items. But you can edit Phrase files (.fkp) from Phrase files folder manually using any text editor.
