Reversing text selection or clipboard
Oblomov
Post by Oblomov » Feb 15th, ’20, 13:50
I'm trying to figure out how to reverse a selection or clipboard.
According to this thread
viewtopic.php?f=4&t=1079&p=3960&hilit=reverse#p3960
This should be used
sort, clipboard, R
And it seems to work with numbers. However, when wanting to reverse these couple of lines
interconnected
connects the threads
part of the mainstream
anyone could watch
international culture
bedrock of marvel
building something
I get this instead
interconnected
building something
bedrock of marvel
anyone could watch
Which seems a little scrambled... I tried checking AutoHotkey forums, but nothing useful so far 😞
Post by Tom » Feb 15th, ’20, 17:19
Sort command sorts the items in alphabetical order so the result is ok.
If you want to reverse the lines order then somethig like this should work:
Loop Parse, Clipboard, `n, `r
	result := A_LoopField "`n" result
Msgbox, % result
Oblomov
Post by Oblomov » Feb 15th, ’20, 20:04
Tom wrote: Feb 15th, ’20, 17:19 Sort command sorts the items in alphabetical order so the result is ok.
Msgbox, % result
That's just what I was looking for, thanks! Is there any way to have it be saved inside of clipboard rather than an FK window however?
Post by Tom » Feb 15th, ’20, 21:52
Clipboard:=Result
Oblomov
Post by Oblomov » Feb 15th, ’20, 22:03
Tom wrote: Feb 15th, ’20, 21:52
Clipboard:=Result
Thanks! I think right now it just aggregates the commands without clearing them however 🤔
asd
has
sas
asd
has
sas
sas
has
asd
sas
has
asd
Clipboard:=Result
Clipboard:=Result
sas
has
asd
sas
has
asd
asd
has
sas
asd
has
sas
Clipboard:=Result
Clipboard:=Result
asd
has
sas
asd
has
sas
sas
has
asd
sas
has
asd
Clipboard:=Result
Clipboard:=Result
Post by Tom » Feb 17th, ’20, 10:32
result:=""
Clipboard:=Result
Oblomov
Post by Oblomov » Feb 17th, ’20, 19:44
Tom wrote: Feb 17th, ’20, 10:32
result:=""
Clipboard:=Result
This fixed it, thanks! ❤
