Hello! I would like to know if it is possible to register a "long press" for a key. I would like to have my numlock key perform the following functions:
1. Single press - functions as normal and performs NUMLOCK on/off
2. Long press - executes "delete" to clear the calculator entry (like CLEAR or ALL CLEAR).
I found some software that can do this called KeyManager from ATNSoft but to be honest I don't want to purchase their software for this one function only and Fastkeys does SO MUCH MORE for me.
Thanks for any help you can provide!
NUMLOCK help
Why not just restricting it to Calculator (no need for long press)?
Shortcut: NumLock
Type: Command
Command:
Window: Calculator
Shortcut: NumLock
Type: Command
Command:
Send {Escape}
As usual, your solution is much simpler and elegant than mine! Thanks! This works perfectly.Marko wrote: ↑Feb 15th, ’20, 12:44 Why not just restricting it to Calculator (no need for long press)?
Shortcut: NumLock
Type: Command
Command:Window: CalculatorCode: Select all
Send {Escape}
