.vbs file no longer functioning properly, in regards to an FK command
Oblomov
Post by Oblomov » Feb 13th, ’20, 19:11
I have a .vbs script with the following code
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.SendKeys "^+%{ESC}"
Which sends
CTRL + SHIFT + ALT + ESCAPE
Inside of FK, I have a command with the same 'Shortcut'
Uptil now, this synergy worked without problems, however today (seemingly after a Windows update, but not 100% sure), the .vbs file, now triggers another command with it, that is assigned to Numlock
Could the update have messed something up, or? I tried restarting, but to no avail. Manually executing the FK command, works just fine
Post by Marko » Feb 14th, ’20, 21:27
There was no recent change in FastKeys which could cause this.
Oblomov
Post by Oblomov » Feb 14th, ’20, 21:57
Probably the update or something of the like then, oh well
